Need flush mounted clock to go along w/ Alpine Head Unit
  • 4
KDB123
I seem to have gotten myself in a slight fix with my '98 Buick Century's double din head unit which has cd/cassette/clock in one unit. Sure it's convenient, but after adding my aftermarket amp and eq, etc., I'm still not satisfied with the sound quality. I understand that is to be expected when using aftermarket equipment with the cars factory unit which has 6 ohm impedance going to the rear speakers. Converters had to be used with this set-up. Have been wanting to put in my Alpine unit, but need a clock. That is THE problem at this time. My Alpine does not have a clock. Does anyone have any great ideas on how I can remedy this situation? Where can I find a clock that would look decent and have fairly close dimensions that would fill the space below (or above) my Alpine? Earmark car audio said they could make a custom installation kit, but they don't know where to start looking for a clock either. Any suggestions would be appreciated. Thanks. KB
how big do you want the clock to be. If thay can make a custom install kit try using a pocket watch or a wrist watch with out the bands on it.
Go to Radio Shack and buy a cheap one...then cut out a spot for it and flush mount it...That's what I did...
pics to follow...
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
462
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
364
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
398
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
606
KDB123
KDB123
Dallas, TX
b0mbrman
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
