Need doors fierglassed!!!!!!!
brandonkain82
your mom goes to college
Who can fiberglass my doors for me. Looking to do a ten,eight and two 6.5 in each door. And two tweets in each door and two tweets in each a pillar. A total of eight speakers and eight tweeters. I would like to get all this done for a reasonable price. If someone has time on the side and can do it just let me know. Thanks
I would see if you can find a facebook group based around your area or near by. Glassing is not that hard really, just a bit time consuming depending on the finish desired and prep work required.
Only way it will be reasonable is if you do it yourself, seriously. If you want to stop by for a few hours sometime I can show you what you need for supplies and how to do it. I would do A pillars first to get your feet wet...
150
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
111
456
351
brandonkain82
brandonkain82
frankfort,il
mlstrass
    May 16, 2024
    May 16, 2024
