Need an amp to power 2 JL 10w1v2s-4
JL Audio 250/1 and make sure you put those 10W1's in a vented box----you will be amazed.I had the same set-up in a sealed box---good--Vented--amazing............................Alpine50...
hey i have a e1200.... ...u intrested?
Specifications
Rated Power (mono):
120 W RMS x 1 @ 4 ohm (12.5V);
200 W RMS x 1 @ 2 ohm (12.5V)
THD at Rated Power:
S/N Ratio:
>104 dB referred to rated power (A-weighted, 20 Hz – 20 kHz noise bandwidth)
Frequency Response:
10 Hz – 25 kHz (+0, -1dB)
Damping Factor:
>200 @ 4 ohm / 50 Hz,
>100 @ 2 ohm / 50 Hz
Slew Rate:
± 22V/µs
Input Range:
200mV – 8V RMS
Dimensions:
9.8" x 9.25" x 2.36"
rmpagejr3
rmpagejr3
Dallas, TX
farmerehsan
