Need Amp Advice - Gonna run a single RF HE2 12
MPDano
I need advice on powering this beast. I do not want to run multiple Amps, so I need a 4 Channel.
The Sub being a Dual Voice Coil can handle RMS 100-200 per Coil.
2 Channels for the Sub (DVC) and 2 Channels for the Fronts.
Any suggestions? Oh, budget is under $175. Used is ok too.
Great Amps linked. I had my eye on this one too:
Product: MB Quart DCS4125 4 channel amplifier
Specs:
Discus Series 4-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 125 watts x 4 chan.
2 ohms: 250 watts x 4 chan.
Bridged, 4 ohms: 500 watts x 2 chan.
I was thinking of running 2 or the 4 channels to the Woofer, then using the remaining 2 for the front speakers.
problem is you will only be able to power the sub at 8 ohm which will be only 125 watts to each coil with that mb quart, great amp, but u really need a single 4 ohm sub or dual 2 ohm sub for its full potential.
jump on that ppi
Whats the PPI? The Infinity? Also, I am confused since the MB Quart has 125 watts times 4. I am using 2 of the 4ohm 125 watts to the Subwoofer. I thought there are separate connectors on the Sub.
yes 2 connecters one for each voic coil. so you will only send 125 watts to each voice coil when that sub wants atleast 200. you will be underpowering it.
http://cgi.ebay.com/ebaymotors/Preci...#ht_656wt_1165
this is a ppi, better amp then the infinity easily. precision power.
FS: Precision Power DCX 800.5 amp - DIYMA.com
heres some more pics, only down fall is its huge over 2 feet long but a true beast, puts out nice clean power.
when new it was a 550 dolalr amp
http://www.precisionpower.com/Manuals/Amplifier%20Manuals/Precision_Power_DCX%20Series%20Multi-Channel%20Amplifiers.pdf
manual
It's rating is 100 to 200 per voice coil. 125 would not be underpowering it.
MPDano
MPDano
Sunny San Diego
MPDano
