Need a set of 3" pods glassed into my Pillars
  • 2
Anybody here do side work I need 3" pods glassed into my window windshield pillars.
I want to stage my 3 way 6.5 components up on my pillars.
Any recommendation? I could send them out !
Or does any one make a universal dash style that can angle a 3" pod facing drive /passenger either dash mount or pillar mount .
Sorta something talking like the extra angle cups that morel audio gives for they're tweets.
Anybody here do side work I need 3" pods glassed into my window windshield pillars.I want to stage my 3 way 6.5 components up on my pillars.
These show tweeter pods but you can do the exact same thing with 3 inch pvc endcaps.
Cheap, adjustable, easily replaceable tweeter pods - Car Audio | DiyMobileAudio.com | Car Stereo Forum
will literally save you hundreds and get great results.
This is a good Twitter idea but can this be also done with a 4" and cap and get good acoustical highs or mids with little to no air space inside these caps?
4 inch mids usually are crossed a lot higher than 150hz so it doesn't matter too much on the airspace at all. Of course i'd do an extra step of some polyfill to absorb some rear wave but unless you want your 4 inch to play deep midbass, I would not worry about airspace at all.
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
127
187
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
141
494
Androidaaron36
Belleville mi
Androidaaron36
audiobaun
    May 19, 2024
    May 19, 2024
