cerwin
Im pretty new to the car audio stuff and i need a little help deciding what would be a good amp choice for my subs.
(2) 10" Punch P3 4-Ohm DVC Subwoofer
specs:
Size 10"
Impedance 4-Ohm x 2
Power Handling 400 Watts RMS
800 Watts Max
Voice Coil Diameter 2.5" aluminum
Motor Size 77 oz. double stacked
Speaker Connector Dual 8 AWG compression
SPL (1W/1M) 85 dB
Mounting Depth 5.9375 in.
(15.08 cm)
Shipping Weight 19.2 Lbs.
(8.7 Kg.)
Rec. Sealed Enclosure 0.65 cu. ft.
18.4 liters
Rec. Vented Enclosure 1.25 cu. ft. (35.4 liters)
Vented Tuning Frequency 40 Hz
specs:
Size 10"
Impedance 4-Ohm x 2
800 Watts Max
SPL (1W/1M) 85 dB
(15.08 cm)
(8.7 Kg.)
18.4 liters
