Need 3000-4000wrms @ .5 ohms or 2 ohms or two 1500-2000wrms amps @ 1 ohm
I have four D4 subwoofers that take on 750-1000wrms each.
I need either two amps that will achieve 1500-2000wrms
or two amplifiers that will do 3000-4000wrms @ .5 ohm daily or 2 ohm.
or an amplifier that is internally strapped to handle two 1 ohm loads (Something like how the Audiopipe AP30001D is. (Two 15001D's internally strapped in one larger case)
This is for a daily driver setup.
I'd prefer 2 ohms over .5 ohms if going with one 3k-4kwrms amplifier.
Budget is under $500 for my friend. He is on a college budget. This isnt for my setup.
[quote name='BIGJEFF64']If u buy @catman db drive 2k u will get 3k at .5. Those amps r serious[/QUOTE]
I hardly doubt he'll see 3k from that amplifier.
Soundstream dtr1.3400 rated 3400@ .5ohm & 2200 @ 1 ohm.... $359 new with warranty at onlinecarstereo. Legit and will do its rated power. Check @taylorfade clamp numbers. 2700 @ rise to 1.2 ohms on only 12.1volts. Serious amp for the price
IIRC a shop in FL who deals with DB drive said that if they get the modded chipset from DB drive they clamped it doin 2800 watts and i think 3200 at 16v. the shops name is T&E Audio in Ft. Pierce but i could be wrong
But since you guys are still here, I have another question. Now that I have a 3k amp, after I get my new battery and HO Alternator, I'll be in the...
272
20K
So you have an 800 watt sub (1600 ios a peak spec, ignore it) the SVR-10 - 800 RMS dual 2VC ohm wired in parallel for a 1 ohm load paired with an...
81
181
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
135
Instigator
Banned
Instigator
Enid, OK
BIGJEFF64
    May 19, 2024
    May 18, 2024
