Name your favourite HU!!
Originally posted by CarAudioAddict I My question is: if you are running a good system why do you need a bass boost
No kidding....I'd rather use my gains, x-overs, etc...I dont think Ive ever adjusted the bass boost on a head unit.
- Steve
Within the last year I have really stepped it up in the hu department. I went from a Panasonic 2 Pioneer 2 Eclipse. I noticed a step up from each brand. I love my new Eclipse, it's not the top of the line but it's not the bottom, I forget the unit number, starts with a 5 though. I put in my Soad cd and I feel like I'm in the f*ing concert. grrrrrrrrrrrrrrrrrrrrrrreat.
Originally posted by CarAudioAddict My question is: if you are running a good system why do you need a bass boost
marketing hype. it's aimed towards those younger crowds that gets distracteced by the word "bass boost". u know how those highschoolers are...//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif i do use my bass boost though. but i do adjust the bass up so i can get some more midbass out of my components.
Originally posted by GSteg marketing hype. it's aimed towards those younger crowds that gets distracteced by the word "bass boost". u know how those highschoolers are...//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif i do use my bass boost though. but i do adjust the bass up so i can get some more midbass out of my components.
What about those Junior Highers? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I'm a little offended by that.. seeing as how im *cough* still in highschool... i never use the bass boost, but i do control the bass/treb on my aiwa //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif hu on a) what my mood is b) type of music and/or c) music quality. anyways...exaclty which HUs out there have no bass boost? -scott
Any alpine h/u, I love my cva 1005....easy to use clean sound....
pioneer premier, unclipped out put voltage (RCA outs) no matter how high you turn it up....until you start using those gay eq presets....
they have one of the cleanest out put voltages, no clipping, until you use those stupid Eq presets....then it will clip....clipping=bad....plus an eq should do those duties, not your h/u...everything on your h/u should be in the middle, nothing turned up, no bass boost etc....it is used to play cd's, and turn up volume, that is it....
ok, ok... thats cool. i am htinking of getting a preamp equalizer though. do you think there should be any problems with that, like will it clip or anything? it will probabaly only be like a 5-7 band and im mostly getting it for the subwoofer control dial
well, i have a clarion peq 460 and i absolutely love it....i can't listen without it...shouldn't clip, but the only problem i myslef had, was that my 1200d, can only take so much input volatage, and the eq put out 7 volts, so it was making it go into protection, but a simple solution was turn the gain down on the eq.....but i highly reccomend getting one....then your deck can be just used to play your tunes, and the eq does what it is supposed to...
that sound good... but wont messing with a whole bunch of gains before amp imput make it sound bad? i dont even know what output this eq does, lemme check it out.
do you think its worth it to get a disc changer and put it in the back or somehting?
Mark_ab
The Alpha Male
Mark_ab
Edmonton, Alberta
soundgy45
