n00b question about volts
Like 12v, 13.2v, and 14.4v or something? That's referring to the input voltages of your power supply, not the signal from your headunit.
Amps usually make more power if your electrical system can maintain a higher voltage. An amp will produce more power at 14.4v than 12v.
gotcha, so its something i would need to test to know properly
Ummmm, no. It;s not really important for you to test it right now.
They are different voltages that amps are tested at. One company may rate their amp at 12v. These companies make amps that may be considered by some people to be "underrated", because they clamp more power than they're rated for when ran on a 12v system that is actually around 14.4v charging.
Say amp A was rated 1,000 watts RMS at 12v and amp B was rated 1,000 watts RMS at 14.4v. Amp A will put out more power on 14.4v than amp B. Amp A may do 1,250-1,500.
Lots of companies rate their amps at different voltages. Most ratings are BS anyways, and you won't see the full potential after rise unless you wire lower than rated.
All you really need to know is -
A healthy battery rests at around 12.6v. That is roughly the voltage you'll see with the engine off.
A healthy alternator runs at 13.8-14.4v. That is what you should get with the engine on.
It really doesn't matter if your alt runs at 13.9 or 14.5. It's not enough variance to change the amp's output significantly.
Install it right - play it - enjoy.
brafferty
brafferty
idaho
n2audio
vegang
vegang
