My US Amps/RE Audio Kia Spec 5
troy_audi0
Top 100 Installer
Well Im About to get hooked up
US Amps/Re Audio & Tsunami are hookin me up
Here is the list og gear
HU~ Alpine CDA-9887
Front~ RE Audio XXX6.5" Comps
Sub~ RE Audio SE15
Front Amp~ US Amps MD21 (100x2@2ohms)
Sub Amp~ US Amps MD1D (750w@2Ohms)
Tsunami
Volt Meter, 1/0Awg, 4Awg, Fuse Distro Block
Fuse Block, 1Frad Cap, Spool 16Awg Speaker Wire
Comp RCA's ect ect..
Iv Only Had A Few Minutes to work on this
So I started with the amp rack
I will be flush mounting the amps on the rear tray
Here are some pix I took..More Soon
Im going to look for a House on the weekend with my wife so
I may or maynot get to the install
I think this may look good...
RE Se15 Specs
15”
Mounting Depth - 7.75”
Mounting Hole Diameter - 14”
Overall Diameter - 15.5”
Bolt Hole Circle - 14.75”
Motor Width - 6.25”
Motor Depth - 3.25”
Basket Depth - 4.5”
Displacement - 0.17 cu. ft.
Weight - 23 lbs.
Compacts Optimal
Sealed 1.5 2.0
Ported 3.0@35Hz 4.0@34Hz
I was not planning on modding the doors much but the XXX6.5's are 3.8" deep so I will be doing my first door mod aswell
I was thinking of doing sealed but I will need to see how much space I can get, If I can squeez 3^ft or more I will port it.. not sure what it looks like yet
I think my tire well is just about 2^ft so If I raise the floor I should get 3^ft.. thats just at a glance
troy_audi0
Top 100 Installer
troy_audi0
Las Vegas, NV
troy_audi0
