My test: Jensen Power 2000.1d
TaylorFade
I fail.
Ok, I know you guys are going to think I've lost it testing a Jensen, but bear with me here...
I started thinking about the shittiest amps out there. Pyle, Boss, Pyramid, Jensen... I looked at all of them and honestly, I can't believe how many amps these companies make. They were all GROSSLY overrated and cheap looking and nothing really piqued my interest to waste money on. Then I figured I'd see what Jensen had been up to. I came across these "POWER" series and a couple things caught my eye. The first was adequate onboard fusing according to rating and the second was this certificate/birthsheet thing...
Now, the amp I got didn't come with one and that certificate is from their 4 channel, but at least it's SOMEthing. There's obviously some sort of quality control going on over there. And that's a good thing. It's kinda fishy that it made *exactly* rated power on all 4 channels, but I figure they just put the rated number if it passes, so whatev.
Anyway... I searched around for the best price on the mono. They only make one in the "power" series. It's called the "2000.1d" but you know how that goes. It's a 1k and it's not the first time I've seen an amp advertised by "max" power. AudioSavings has 'B' stock ones for $105 shipped. Sure... why not.
It's actually a decent looking amp. I usually don't care for "shiny" anything, but the gloss finish is pretty sharp. I didn't investigate the sink material, but it's a little beefier than other budget 1k's I've handled. It weighs in at a tick over 6lbs.
4awg power and ground. 8awg speaker terminals and (4) of them. And by golly... look at that. 105A worth of fusing on a 1k. Now, that doesn't mean a whole lot on it's own, but it's a start.
Input side is... whatever. The usual suspects here. Cheaper plastic pot adjustment. Can't ask for a whole lot at this price point, I guess. It comes with a bass remote that's a 3.5mm jack. More on the bass knob later.
Here be de' guts. As usual... I'll let you guys play amp expert here.
On to the testing...
Setting it up unloaded. Hold the eff up... 51v? That can not be right. Anybody know how to tell if an amp is full bridge? Because that's a lot of voltage. I'm told the little black box in the lower left hand corner of the guts is a switching transistor. So... half bridge. Sheesh. That's a lot of ACV for a half bridge 1k. Well... whatever.
I only had 1 ohm nominal available today. I fully intend on beating it up later.
Here we have 457w rising to 3.6ohms at 13.2v. Staying pretty clean here.
Getting rise down we get... 789w rising to 2.3ohms at 13.3v. This is where, unfortunately, we pick up a little distortion.
So, rated and apparent power.
Rated power ---- Apparent -
- 450w @ 4 ohms --- 457w @ 3.6 ohms
- 725W @ 2 ohms ---- 789w @ 2.3 ohms
Measured efficiency at 2.3 ohms - 73%
Little guy is getting pretty **** close. Now, let's talk about the wave in the last pic. I am going to do something I never do- and that's to cut an amp a little slack. I'll grant you that it's not the prettiest wave in the world. But first... the amp is rated at 2% THD. And second... it's not so much clipped as it is... distorted.
Since I know this little amp at this price is going to be compared to the AP/VVME stuff, I'll go ahead and do it for you.
Here's a side by side of the guts for your convenience.
Here's a side by side of similar apparent power clamps. Both doing ~ 780w. The VVME needing 1 ohm reactive to get there (but at 12v) and the Jensen doing it at 2.3 reactive (13.2v). What you'll notice here is the wave between the two. One is "clipped" and one is distorted. One is going above and beyond it's capabilites and the other is kinda... noisy.
I'll leave my personal opinion out of it and let y'all draw your own conclusions.
So, one little footnote about the bass knob before I'm done here. The knob itself is actually pretty nice. It reminds me of a more expensive amp's knob in its heft and action.
Buuuuuuut.... this thing is garbage. And I mean hot garbage. First of all, most knobs will basically shut the sub completely off at "min". Not this one. It may have attenuated it about half. And second (and more importantly), it distorted and clipped the ever loving hell out of the signal at anything over 1/4 knob. Most knobs will *only* go to where the gain is set. I have a feeling this knob is more like a bass boost. Moral of the story... don't use bass knobs. Especially this one. Geez.
Ok, I'm out.
Not too bad. Around 800 watts for 105 bucks... I was under the impression Jensen sucked a lot worse that that. Lol!
for local budget builds, i have used these and there little brother power900.1 and power 760.4 i have been impressed for the cost to output ration. (and easily accessible for me) But seam like a decent little amp, and i have not had any come back to be honest.
the best part about these amps they come with "If it's to LOUD your to OLD!" sticker lol!
do you not have a job? that's the only explanation I can think of as to why youd have the free time to check Chinese garbage that nobodies interested in. we knew its crap, we dont need an idiot like you "testing" it for us with a cheesy Amazon special oscilloscope.
Lol.
The bad thing about forums is tools like you. Let the guy test away without calling him an idiot. Seriously whats your problem. The guys giving info on an amp and your complaining. Grow up man.
BTW RLDiverv2, I looked at your post history. Almost every post you have made is knocking someone, or negative in someway. How exactly do you contribute except for bashing people? Hopefully the mods look at your history and give you a nice ban. Not sure what it takes to get one, but I'm sure your on track. At least you should be. BTW thanks for the info Taylorfade.
RLDriver has confessed openly to coming on here to troll, and once you keep that in mind you just need to ignore him. Thanks for the report, Taylor.
TaylorFade
I fail.
TaylorFade
Baton Rouge, La.
trumpet
    May 16, 2024
    May 16, 2024
