my spl score from today
not bad. im pretty sure thats TL they use in that circuit. for a TL that score isnt bad at all for a single 12 with 110watts. hell my xxx15 ina wall with 1400w in a 92 maxima did a 140.7....ur not far behind at all. good score
Hmm...really with any sub and over 1k watts...you should be able to do 140s.
I did 144 with my Type R 15 and 1200watts...and that was at 37hz. In a 4dr trunk car facing back to.
Play around with tuning and putting box diff. you should break 140s easily with 1100watts.
Good Luck
i did 144.6 on the TL in the kick with my set up in my sig
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif the 40.1 is only running at 2 ohm due to the single 4 ohm coils of the LMT's so thats 1800 watts...
Trade that 40.1 for 2 Kicker 2500s or other 2ohm peak amps...should see a small raise in score:laugh:
I did a 137.5 on the TL with one 15" custom TC9 hybrid on only with 500 watts RMS. The sub is in a 2.5 Cuft box tuned to 32hz. This was in a Mercury Sable, backseat down and sub firing into the cabin.
you should turn your box around because if you let the sound wave past the woofer into the trunk it cancels it out some... you should be getting higher than that though. im going to build a board that will go onto the baffle of my box and seal off my trunk i should gain a little from that. i also need to put some sound deadening mat into my car i have none at all.
htownplaya456
htownplaya456
Austin
Pyro_By_Nature
