My:Soundqubed Q4-120 for your: Sundown SAE/SAX 50.4
adjetta
I want to trade my Spundqubed Q4-120 (specs bellow)
For your SAX/SAE 50.4, cosmetically and mechanically my amp is excellent, I'm not to picky about cosmetics of yours, so long as it functions 100%
I pay shipping for mine, you pay shipping on yours
View attachment 26551333View attachment 26551334View attachment 26551333View attachment 26551334
High power 4 channel class A/B output section.
The 120.4 features variable high and low pass filters that can also be used in a band pass/full range configuration.
Remote gain control knob w/ clipping indicator
Specifications
Model Q4-120
Dimensions 15.75" x 9"
Input Sensitivity 8V~0.2V
Low Pass Filter 50Hz ~ 5kHz
High Pass Filter 20Hz ~ 5kHz
Crossover HPF/FULL/LP-BP
Remote Gain Control Included
Clipping Display Led Yes
Signal to Noise Ratio 105dB
Damping Factor 200
Bass Boost @45Hz 0~18dB
External Fuse Rating 40A x 2 pcs
4 ohm power @ 14V 120Wx4
2 ohm power @ 14V 170Wx4
4 ohm mono power @ 14V 340Wx2
Power and Ground Inputs 4ga
Out of curiosity why are you downgrading? Good luck though.
My thoughts exactly thats a huge downgrade in power unless u just want to match all sundown equipment ..that could be the only logical reason.but nevertheless good luck
Like the others I too would like to know the reason....
Was the SQ amplifier not performing well?
And I meant for trade if you wanted to. Sorry I wasn't more clear. My bad. What I meant to say would you be interested in trading the soundqubed for my Sundown sax100.4?
Thx
Looking to buy 1 Soundqubed hdc4 15” basket/ frame with gasket.
586
adjetta
adjetta
Louisville
big scott
    May 31, 2024
    May 24, 2024
