My Re Mt Came In!!
take cap lock off please....get more power, a 4 ft^3 with 90in^2 of port tuned to low 30's...whats the configuration on your sub?[/quote
srry bout that caps....config. on what? its 5000rms, 1.4 ohm vc., i have the recone for it at .7ohms, 15"....idk bc i bought it used.....
you need a better amp and better sub, there is no rating for a mt tech. it will take whatever you throw at it... as long as you arent clipping the hell out of it, but in your situation you are clipping the hell out of it...
putting a bigger load on the amp at which i'm sure it won't be able to run at for a long time, plus u have the gains 3/4 up in most likelyness your clipping your amp
keep the sub, get a new box, get a 2500D or a similar amp and run it a .7 ohms....
x2
for a MT 15", i'd say AT LEAST 4 cubes, with ALOT of port area (what people have already recommended).
You are definitely not doing that sub justice with the box it is in now.
DJ CHAOTIC 666
DJ CHAOTIC 666
Arlington Hts, IL
adio
SPLBassJunkie
    May 21, 2024
    May 20, 2024
