My pg rsd65cs review as promised
If it were 1200wx1 at 1ohm i would be all over it. Why would they make dual 4 ohm 12" woofers and then make an amp that puts out enough power for 2 of them but isn't compatible with them ?????
Because they make a single 4 ohm sub. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
oh yeah, it will get a review, but i am still working on the final box design and then i actually have to build it once i figure out how I want it. And then i have to buy an amp. I need 1200wrms at 1 ohm on the cheap. I will probably have to get it after christmas.
I'm looking for an amp at 1200wrms too and if you can get in on the audioque pre order its a pretty good deal. http://www.audioque.com/aq/AQamps.htm. Not sure if I can come up with the money before jan 1st so I might have to pay the after pre order price which would ****. The ednine.1 looks to be a good amp too and is rated at 1200wrms at 12.5v which is nice. It's a little more than the AQ amp though but not much after the pre order sale.
So would plumbers putty work in place of the non hardening modeling clay for in between the mdf baffle and the door??? It's also non hardening. Just curious cause I have plenty of it but no modeling clay layin around lol.
anyone know the driver displacement on rsd 12"s? I ended up giving them 1.5 cubes each after taking away for the wood itself. Take driver displacement out of that and throw in the 2.5lbs of poly fill i am thowing in each side and they should be right at 1.6 ish cu ft per side that they are actually seeing. I will let everyone know how they sound as soon as i get the box wrapped and get an amp. And of course i will provide plenty of pictures //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Mine should be here on wednesday. I'm going to put it in a 1.2cuf box i have layin around with poly fill till i can get a new box built that is 1.8cuf which will hopefully happen this weekend. I'm going to build a false floor at the same time. If it would ever quit raining so i can get the mdf board into my dads shop. I will be using my mtx 801d for now but as soon as i get my taxes back i'm getting another 12" rsd and a 1200 watt amp.
sounds like you have a workout in front of you. I lift weights every other day and my ****in legs are killing me from all the weird positions i had to be in while building my box lol.
Let me know how much power they take in the 1.2cu box because it might change my mind on what amp i'm gonna go with. I wont be gettin one til after i get my ebay gift cards for christmas.
skydeaner
suede humper
skydeaner
Champaign, IL
skydeaner
