my mtx 9500 isnt loud enough :\
GiganticPrune
so i used to own a 12 inch 9500 in the sledgehammer box with a mtx 1501d (new style) and it sounded really nice, just wasnt quite loud enough. so i went ahead and got ahold of a 15 inch version and a kicker zx1500.1.
so i build the box per mtx's specs in the manual @ 2.48ft^3, and im pretty disappointed. i expected this thing to wang out like crazy.
will changing the box design change things that much? is there a different design i could get that would just have huge spl numbers?
i would give it more power.. and a diffrent box design...
All you basically did was upgraded from a 12" to a 15" with the same power. You are expecting too much. Should of just added another 12, and another mtx 1501d amp and it would of been a big difference.
well the 1501d tested out at 1100 something watts at 2 ohms and the 1500.1 tested out at 1700 something...so quite a bit of difference as far as power and surface area of the sub
sig check...
my shit is loud //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
i have no numbers to back that up but it is.
1501d should put out WAY more than 1100 @ 2. you have it at like 11v or something?
sig check...
u got the v8?
sig check...
yeah really you must have no electrical upgrades man only 1100 watts at 2 ohm outta that amp.
im going off of the birth sheet that was shipped with the amp. obviously thats at 14.4 volts, my only electrical upgrade right now is a yellow top under the hood. i have a HO alternator sitting in my garage im too lazy to put in for the moment.
and for the record, its a 4 cylinder turbo wrx..
and as much as id love a DD sub, im sticking with MTX or Kicker due to the amazing Circuit city discounts i can still get through my buddies.
and people are saying i should have gotten more outta my 1501d's...i ordered 2 of them, both put out around 1600 something at 1 ohm..i dont think the thunder elite versions are as awesome as the older ones you guys are probably referring to
go old school or go home (cheaper too)
GiganticPrune
GiganticPrune
Orland Park, il
HellsRise
michigan born
    May 14, 2026
michigan born
    May 14, 2026
