blazian87
I have an optima yellow top right now and a 165amp high output alternator with the big 3 done with 1/0 gauge wire. It was an OEM alternator for my car that was modified to go higher. I can't fit any of the beefy aftermarket ones so I'm left with upgrading my battery. I want to go with the XS D5100 battery because that's the only one that can fit under my hood. I'm running an Audioque AQ2200 amp and running parallel at 1 ohms. Would this XS battery be sufficient in not making my lights dim? Will running a 2nd battery in the trunk be a big advantage or will it strain my electrical even more? What if I decide to upgrade to a 3500w amp? I would rather not buy a 2nd battery for the trunk but if it makes a significant difference in how it performs, then I'm open to the idea.
