My head unit works but keeps blowing fuses, i need help
well I tried to reply to this question a min ago but it didn't post so here it goes again. What you may have done if in fact you used the cut and splice method of installation rather than using a harness, the wire you are using as a ground may be the dash illumination. If this is the case if you probed the wire with a meter, it wouldn't show anything untill you flipped the lights on. Does the fuse blow when you turn the lights on at night?? If so find yourself a good ground for your radio
Go to your local car stereo dealer and ask them to help. I had the same problem after i got my system installed,so I went back to the dealer and they fixed it for me. That is my suggestion
490
760
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
803
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
bigjon16
bigjon16
St. Charles Illinois
Caveman
