My first meter readings
Mtndew
Loud s10.
Yesterday i went to a local audio shop and had my DD3515 in a 5.5 cube box @ 32 hertz im my ext cab s10 metered. I did 137.4 legal and 147.3 outlaw in the port with a 38hz peak.. this is my first time being metered and will be looking for improvements as i go. i plan on doing a blow through in the future how well was this score for my first time?? Any advise and thoughts would be lovely..
well its 5.5 before displacement and port.. and i have a Planet audio PDX 2000 watt amp at 2ohms on it right now its grossly underpowered but i got the amp for a pretty good deal so i cant complain.
I dont think it's too bad. With a truck though I would guess you should hit 140+. I did 136 with 2 12's in a prefab box in my astro. Another guy did 144 with 3 10's in an S-10. I think you're amp may be the weak link.
I doubt its the amp... it should be pushing 1kw at 1 ohm...
a single decent 12" in a decent box will hit a 137 easily on 500 rms... in the cab of a p/u truck...
2 12's on 1500 will do a 145 pretty easy in a minivan or suv...
and in the port? thats a realllllly low score for a port...
I did a 137.9 out of a trunk on a single 12 and 750rms...thats with the car off and metering on music...so that score seems pretty low
Just needs some tuning. Should have plenty of room for improvement. I did a 137 legal with 2 8's and 700 rms so you should easily be able to get into the low 40's
easily into the 40's...
I wasn't gonna post our results but since others did we are doing 139 in a trunk of a single 12 and 500 rms
147.3 on music and 150.1 in an suv on 2 12's and 1600 rms..
the 139 is on a zeus sub in 2.6cf tuned at 36Hz with a 50hz -3db tone in a 99 alero and a dsc480 using the dupe function and bridged
the 147 is on 2 old school brutus on an old school brutus amp at 15 volts in a 2000 windstar in 3.5cf tuned at 38Hz
both enclosures were designed by the trunk car champ M Stiers to be musical and still very loud.
me and my customer could not be more happy with the results lol
Not bad. I think I am around 139 on a tone, but with 750rms rather then 500...
im not looking to seal off im trying to stay out of wall classes and plan on staying in trunk classes
15
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
Mtndew
Loud s10.
Mtndew
Tennessee
Louisiana_CRX
audiobaun
    May 19, 2024
    May 19, 2024
