My car is leaking something...help???
would help if we had a color, but if your sure its oil, I would check the oilpan for holes, or the rubber ring around the bolt on the oil pan, those go out pretty commonly. If its green check radiator, check upper and lower radiator hoses, look for cracks or splices, check power sterring pump/hoses for visible signs of wear and tear, checkl brake lines, and also, if you have your AC on, and been using it for awhile, water and condensation will drip of the condensor and evaporator. lmk if this helps. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
aslo, if itsd transmission fluid, (sorry just seen that) and you have a enclosed system, you wont be able to check it, you will have to go to a transmission shop, if you have a cottman transmission where you live, they will check it out and diagnose it for free.
What color is the fluid? it might just be condesation dripping down also happens when it's a summer day humid putting the a/c on . but with your pic doesn't look like nothing there.
find out where the leak is coming from and add fine sawdust in the resevoir....it will seal all leaks...most used car lots use that on the vehicles they sell //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif proven leak stopper...
YOUR stupid, its not blinker fluid its headlight fluid:wow://content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
don't forget to use a can of clearance before you add the headlight fluid.
is your car a manual ****** with a hydralic clutch if so chances are its that... when the throwout bearing starts to go out they leak clutch fluid like a siv check the resivour if its low u can add dot3 or dot4 break fluid to it
i use to have a friend that had really bad leaking brakes in his chevy luv pickup.....finally he decided he wasn't gonna spend anymore money on brake fluid and decided to use water since its a fluid also and they both flow...It worked for a few days //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you dont seem to find the source of the leak just place a piece of clean plastic under the car tonight and tomorrow you can look at it as its not gonna be a stain in the ground...
JLa Obsessed
Just Florida Chillin'
JLa Obsessed
Melbourne, FL 321 Represent
evilxxx
BP1Fanatic
BP1Fanatic
