My box/subs just eat up watts
Unfortunate
Umm...
well i think its my box or the tuning
2 dd1510's
2.8 cubes 2 4" aeros
38hz *supposed to be*
amp: sundown saz-1500
For the amount of power pretty much i'm sending to them the output is just ok.
Last setup was tuned to 32hz and it slammed the lows and hit the really higher frequencys Better than my current setup that's tuned to 38hz which sounds blahhhh not very musical but maybe i'm asking to much
wtf
sundown saz 1500
never had dimming problems
1ohm so they'll be seeing around 750w each once they're full broken in
have you ever read your volts while the subs are banging?
Seems like a possible voltage problem?
possibly a mistake in the wiring? maybe its at 4 ohms instead of one?
Did you set your gains properly?
Also, once the broke in you may see a large improvement.
I have a volatage gauge and i stay at 13-14.3 idle so that can't be the problem
It's 1ohm
Set the gains a little over half way with a DMM. should be around 1500w
are they wired out of phase?
No, i check that already. Got a 1ohm load readout
what are the dimensions of the box and length of aeros?
30w x 17d x 13h
aeros are cut to 14.8 inches Flare end to Flare end
( thats how you measure or did i do that wrong? )
Unfortunate
Unfortunate
Norcal, CA
Unfortunate
