My boat needs a system, I need your help choosing my equipment
Wattser93
I have a Glastron GX185 boat, it's 18.5 feet long, has an open bow, the full rear sundeck (space for a sub box, amps, etc... about a 15 cubic foot area if needed for all that stuff)
The speaker mounting options are very, very flexible. I'm looking to have speakers in the open bow (lowest priority), driver/passenger (highest priority), and the rear bench seat. I also want a sub, will be mounted in a box under the rear deck so I don't NEED a marine sub because it won't be exposed to any spray or anything from the water, it will be dry all the time. The boat sees about 15-30 days a year on the water and is stored inside a garage so it won't be under constant exposure to the elements. The system will be ran off of an iPod 99% of the time.
I'm thinking 6.5" 2 ways in the front, 6.5" comps in the driver/passenger area, and either 6"x9" 2 ways or 6.5" 2 ways in the back, probably one in each box (boxes are my only mounting option in the back) on either side. I was thinking a 12" or 15" sub, I already have a Type R 12" DVC 4ohm lying around so if you think that will be good enough that could save me some money. Those are the sizes I was thinking about but you can suggest whatever you think will sound the best for my build. I also have a Jensen CD3610 deck lying around too if that makes a difference.
I know that audio is expensive but I'd like some recommendations based on the following budgets.
I'd like it to be under $500 but I'm dreaming with that budget. $1000 max but less is always better. I'm not an audiophile and on the water acoustics **** anyways so it's more about being loud than sounding good.
I have 4 gauge welding wire already and have 16AWG wire right now but have up to 8AWG readily available if needed so my budget is solely based on speakers/amps/sub/material for sub box, will be making the box myself (sealed preferably, much easier plus I like the way a sealed box sounds over ported) based on specs you guys provide me.
Thanks for you time and I look forward to the suggestions.
PS: The Bose system in my 2001 Denali sounds good enough for my ears so as long as what you suggest sounds as good as that I'll be a happy camper
I use "Poly-Planer" 8'' co-axials in my Mastercraft. I have four, 2 in front bow and two in rear side panels. I have 4 8'' Kicker L7s for the substage, i have 2 under each side of the dash. Also have H2O tower cans with Kicker 6.5" co-axials. My HU is a Kenwood X-792 and i run all Series VII Hifonics O/S amps. Electrical consists of dual 70Amp marine alts, 3 Kinetik batteries (one for starting and two for reserve wired through a 100amp isolator). I don't have any pics of just the stereo, but here is the boat.
The first thing you should look at, Is your Electrical, And what it can handle. Also, Would it be easily upgradable?
Whats your budget?
If i were you, Beings you want it to be run off of a Ipod, I would start with a nice half din EQ. Make sure the EQ has a sub out as well (Or your amp has a "Threw / Output", However i dont know if the output would just out out the high freq's being sent to the 4ch, So id go with a sub out.). Ipod input into the EQ, EQ out to a nice 4 Channel amp, 4 ch amp to your speakers. [if you decide 6 speakers total, There are several ways you could wire them to the amp. I would personally run ch 1 and 2 to the bow speakers, Then run channels 3 and 4 at 2 ohm's, to your componets or whatever you go with in the mid area of the boat.] Or you could do a 4ch, And a 2 ch, But keep in mind your Elec system WILL limit you a bit.
Your Type R should suite the stereo well, beings im sure your not going for SPL, just something to listen to. However Type R's do have decent output. Maybe a Transmission, 4th or 6th order bandpass, Since you have all that room for your substage? on something like a 750.1.. Should be plenty.
Pics of the project? I had a boat i was gonna remove the front window's, And mount my mids and tweets there. Then i was gonna turn my open bow into basically a tanning deck, With my sub stage under it, Deck in the glove box, Coolers, Ect.
Then the guy who gave me the boat, Got it stolen out of his yard. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Wattser93
Wattser93
Sparks, NV
z0n3d0u7
