My best option for 300 watts
I have 300 watts, and the whole rear cargo area of a ford expedition for a sub set-up. I plan on buying 2 15" kicker comp subs and dropping them in 8 cubes with lots of port area (using the recomedation on the kicker site accually).
Do you guys think this will give me the most output i can get with only 300 watts?
If i go this route, which direction should i aim the subs and the port?
Thanks for reading
My 300 watts is the 5th channel of a hifonics amp (forgot model number), but it is 300 watts at 2ohms.
I don't think a type R would move much with 300 watts. They are what, 750 rms?
I figured the comps are 250rms each, so 150 watts each should get them moving...their Xmas is 11.53mm (not bad for a $75 15")...dropping them in the largest ported box they can stand should make them efficent.
I have 4 RE8's right now, but i am under powering them by a good bit...moving to the comps, i would be over doubling the cone area, and the 15's would probably use more of thier xmas then the re's because i'm closer to their rms power...Am i missing something?
FordExpoMan
FordExpoMan
Panama City FL
Cbass
