bingo.but there should only be two wires running into the fuel pump kill switch if there is just cut those two and wire them together
Only use a toggle switch if you need to kill fuel pressure to work on anything fuel related on the car.
for one thing a stiff toggle shouldnt get tripped by bass and also you can move the switch somewhere else in the carso with toggle switch, just leave it in the off posotion?
---------- Post added at 11:05 AM ---------- Previous post was at 11:04 AM ----------
lol, gorilla tape does hold iisssh dwn
---------- Post added at 11:06 AM ---------- Previous post was at 11:05 AM ----------
ill try n check on that the harness only has two wires if i can find out where they go then ill wire them uplol yeah man do another kill switch that should get rid of it. look in your manual for the wire codes when doing it. thats about the only thing you can do
thanks for the help but my whole thing is if i alter it from popping when my bass is up then what will happen when i actually get in an accident?Maybe some thick soft rubber washers for the mounting bolts between the side panel and bracket and wrap it in a material that will buffer the vibrations. Never had this problem in my 98 but your's also looks louder. Check out crownvic.net, maybe they'll have some better suggestions.
lol..yes i dolol you got a problem. weird problem but a problem.
thanks for all ur insight..i think what ima try to do is just take some the stinger roadkill i got left and put a few layers around..and ur right cars blowing up is rare but u never know...i just want that bitchto stay down so i can jamJust about every other type of vehicle has that issue??Whats the difference?Ford made those cars for the Law enforcement production line to try to help the enforcers with the issue of cutting the fuel off due to a couple of freak accidents with theyre own.What other vehicle on the market has this feature, and how many vehicles have you actually seen blow up from getting hit in the rear??I mean really?Not trying to be sarcastic man but..just think about it for a few minutes.Only other option that I can think of, is like back in 92 when i used the portable cd player into the cassete player..Not sure anyone remembers those days?? But,That thing would skipp all the time on me unlessi put it in my lap.So I made a flat piece of plastic and bought some washers, and wood door spring, and cut those out, and bolted it to the floor, and the bass would hit, and it would move but didnt skip??Later on, they came out with a plate like that, but the springs werent good enough, and expensive,or Bite the Bullet, and do the toggle/Either live with it, ordue without it?Thats Modification/dedication as they say..LOL
naw i dont think the switch is bad its jus where the box is placed and there is so much vibrations in the trunk it triggers itHave you tried getting a new switch, or from a junk yard?? go to one of those pull your own part, open all the fords and see if they match (up in plug). Maybe you have a bad switch,
