My amp is to large. what to do?
Its only a single w0 so i cant wire in series/parallel.
If i keep the volume low will the sub get a low enough power?
I am going to use a loc right at the factory sub so i have a setting on my deck to lower the sub. Will this lower the power the sub recieves?
I do plan on purchasing a new sub/amp but not for a few months. I would like to have something to use for the time being. Any other help/info is greatly appreciated.
is it the rockford fosgate P5002 punch amp?
if so:
# RMS (Continuous) Power: 125 W x 2 @ 4 Ohms
# RMS (Continuous) Power: 250 W x 2 @ 2 Ohms
# RMS (Continuous) Power: 500 W x 1 @ 4 Ohms
just wire the sub up to one of the channels.
if it is a mono amp that does 500W at 4 ohms (i doubt it) you just need to keep the gains low.
read this:
http://www.caraudio.com/forum/showthread.php?t=164826
and set it to do 125W @ 4ohms
Yes its a punch500a2.
Someone told me that if you dont have a speaker hooked up to an amp while its sending out a signal you can burn it up easily. Is this true?
Applying the above logic to using only 1 channel of the amp, is there anything to worry about since one of the channels will have nothing hooked up to it?
I will use the linked amp setting when hooking this up tomorow.
thanks a ton guys. Its pretty awsome to get such knowledgeable answers so quickly.
thanks for the offer but i just want a single 12" sub.
I had 2 w3's and a jl 500/1 but gave them to my brother thinking i wasnt going to do any more car stereo stuff. Two 12's was too much bass for me....kickin myself now.
MattGeorge
MattGeorge
WV
MattGeorge
