my 6x9s are clipping
BLACK12
my 6x9s are clipping when i turn my system up. they are jbl 350 watts each. im looking for new ones but dont know what to look for. should i go for speakers with more watts?or just better quality speakers. i was looking at these 4 way 1400 watt 6x9s but im not sure.what do u think?
How is your system set up? Are you amping your 6x9's or are you running them off your headunit. If you have an amp on them, what is the rms rating of the amp and the rms rating of your 6x9. JBL makes so pretty good 6x9's that can had some decent power. What do you have....we need more info to properly answer your question....... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
LOL @ 1400 watt 6x9s
But yeah...answer the aforementioned questions and we can help ya out.
I have JBL 6x9's GTO series 100 watt rms 300 watt max powered with a profile 100 rms x 2 at 4 ohms and i have my gains a little lower then half and no bass boost running off the amp i just use the X-Bass off my headunit and they sound good so if there clipping you have your gains to high off ur amp or the bass boost is on and if ur running off HU then you might have a wiring problem.
I'm really not understanding the last half of your statement, it almost sounds as if you are anwserring your own question. Try turning your gains all the way down and when you use your x-bass on the headunit now see how it sounds, also what is the bass cut off freq set at on your amp, because you 6x9's really aren't made to drop bass at the same level as a set of subs... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
......... I know they dont but mine do :] naw but i dont set my gains high because i want that extra room to turn the x-bass on because i really rather have SPL then SQ
If you have a sub, set them to about 100hz and let your sub grab the rest. It will move the soundstage, but if your soundstage sound like crap otherwise, you could probably live with it.
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
763
Don't recall off hand. Both single dins. One excelon, one not.
939
1. make sure you wired your subs right... https://jlaudio.zendesk.com/hc/en-us/articles/204374200-Dual-Voice-Coil-DVC-Wiring-Tutorial 2. set...
10
Even a basic TL072 will do this function just fine. LoL. The joys of comparators!
34
6K
BLACK12
BLACK12
WILLINGBORO NJ
lexiphanic
audiobaun
    May 19, 2024
    May 19, 2024
