Must sell my amp ASAP!!! Buying heads for the stang and need some extra csah!!!
Pic is below..
Variable Low Pass 40Hz-120Hz
• Variable Hi Pass 150Hz-1.5Khz
• Bass Boost @ 40Hz. & Variable 0-18 dB
• Frequency Response: 20Hz to 30Khz
• S/N Ratio: 97 dB
• Three Way Protection Circuit
• Tri-Mode Capable • 2 Ohm Stable Stereo
• THD: 0.02%
• System Distress Indicator
• High/Low Level inputs With
Floating Ground
• 4 Gauge Power/Ground Connection
(the beow ratings may be slightly off. The amp isnt made anymore so I tried ot match them as close as possible)
180 x 2 @ 4ohms
230 x 2 @ 2ohms
470 mono
840 bridged max
$100 or FIRST BEST OFFER TAKES IT!!!!
Pic is below..
• S/N Ratio: 97 dB
• THD: 0.02%
Floating Ground
180 x 2 @ 4ohms
230 x 2 @ 2ohms
470 mono
840 bridged max
