multiple batteries
You do lose a minor amount of voltage when using an isolator, that said though, I would rather lose a little voltage and know that my car will still start. Running 3 batteries is going to put quite a strain on the alternator, can the alternator handle this?
What kinda of batteries? No your alt is not big enough! What are you in need of 3 batteries for then we can perhaps help you better. A optima yellow top under the hood or 2 under the hood is VERY sufficent for any case other thing big time competitors. If you get a 200amp alt you can build a battery tray and run them under your hood or get a batt iso and run 1 in the front and 1 in the rear and I assure you should have enough power.
DeepMag1c
DeepMag1c
Jackson, MS
Mr. Loki
michigan born
    May 14, 2026
michigan born
    May 14, 2026
