Multiple Amplifiers
stangaudio
I have a kenwood amp with these specs
Class D Monoblock Amplifier
# Maximum Output Power: 1000 watts
# RMS Power Output:
* 300 watts x 1 channel @ 4 ohms
* 500 watts x 1 channel @ 2 ohms
# 2 ohm stable
# Frequency Response: 5 Hz-200 Hz
# Low-Pass Filter: 50 Hz-200 Hz, 24 dB/Octave
# Variable Input Sensitivity: 200 mV - 5 V
# Line Output Terminals for Extension
# Infrasonic Filter: 15 Hz, 25 Hz, 18 dB/Octave
powering two kenwood subs with these specs
Two 10" Subwoofers with 4-ohm voice coil
* stainless steel-coated polypropylene cone with rubber surround
power range: 50-300 watts RMS (1000 watts peak power)
frequency response: 30-800 Hz
# sealed box volume: 1.0 cu. ft.
# ported box volume: 1.25 cu. ft.
# Power Handling:
* 300 watts RMS per sub
* 1000 watts Peak per sub
* 2000 watts Peak per pair
and i would like to bridge it to a power acoustik amp wit these specs
* Full Selectable Crossover Hi/FULL/Low * Three Way Protection Circuit * 2 Ohm Stable Stereo * Tri-Mode Capable * Variable Low Pass: 40Hz-250Hz * Variable High Pass: 40Hz-250Hz
i use the power acoustik to power
2 6x8 4 ohm pioneer premiers, and two alpine 6x8 power range: 2-75 watts RMS (230 watts peak power)
I have the RCA's from the HU going to my kenwood amp and another set of RCA's going from the rear speaker wires through a high low converter to my power acoustik amp
when i turn the volume up past 20 on my hu which is a sony xplod the subs will cut off and the amp for them will stay on and the 6x8s will play fine
I have a 5 gauge power wire going into two 8 gauge power wires for the amp through a distribution block from scosche and two 8 gauge grounds going into a seat bolt in a 99 mustang coupe
why do the subs cut off when i get past 20?
I have a kenwood amp with these specs#
# RMS Power Output:
# 2 ohm stable
# Power Handling:
out of phase!
stangaudio
stangaudio
Miami, FL
stangaudio
Mike Mccabe
