Multi Subs different brands
SubFocus
I hear all the time dont mix different sizes of subs and that i can understand. What about same size subs but different brands? I have two 10in CVT kickers and one 10in JL 10w7, i put them all together and it seemed to sound good no problems or anything but im not too sure if its safe. No one ever has a concrete answer so any help?
i also checked the specs for each sub and compared they dont really differ too much except they 10w7 can handle more power than the kickers.
Extra info: running a exile 2400.1, 1 ohm stable, 4 gauge wire.
Hell..If they are running fine...then run them till they give..Blow.If they sound fine to you, then ,hey..Run them..I hope they last you a bit..Good Luck with this..Each to his own:santa:
What everyone is saying is different subs have different power draws and can damage amps or the subs themselves. Like the more power drawing dominant sub will take away from the others. Or they may just draw way more than the amp is capable of dishing out.
SubFocus
SubFocus
Chehalis,WA
SAbass15
NorthFramingham
    Jun 30, 2026
