multi-channel amp, recommendations
M@nJo
my setup is polk ex3560 component 6'5" up front, JBL GTO 936 6x9 coaxils in the rear, an a hifonic brutus amp thats powering my 2 12's.
im looking to invest into a 4-channel amp that will make the music out of my speakers sound super clean, crisp, loud, at any volume level given. i have the subs for the lows and my components are rated 50 fhz-xxxxx. there capable of 10-100rms watts per speaker and i would like to give it at least 50rms each.
my budget is $150...but im mainly looking for an amp thats best bang for the buck.
but here are few problems: im running 4ga power wire and a brutus bx1000d is comming its way. i want to keep the 4ga wire to save the hassle of running new wire and buying it. so i want to keep the 4ga and hopefully find a distro block that offers a "4ga in > 4ga + 8ga out. 8ga, being for the speaker amp. unless the speaker amp takes 4ga too, then im sure a T block will be fine.
on top of that, im running an AGU 60amp fuse by the battery. i want to keep the agu fuse style holder. highest ive seen is an 80amp agu fuse. but i doubt there are 4-ch amps that use a single 30amp fuse?//content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif
what i don't understand is why people think it's cheaper to half *** an install? just go to http://www.weldingsupply.com and get some 1/0 gauge wire. it is fairly cheap and will only cost you $20-30 at the most. then an anl fuse holder can be had for $10. now a very good amp would be the us acoustic 4065. does 65 watts rms x4 @ 4 ohms at 12.9 volts. it's underrated. very nice amp. can be had brand new from an authorized dealer for about $150
M@nJo
M@nJo
bay area
Symon_say
