MTX THUNDER 6000's
  • Thread starter Unregistered
  • Start date
  • Replies 3
  • Views 1K
  • 2
U
Unregistered
Guest
i was looking at getting thunder 6000 enclosure with 3 10's. Do you think this would be a good choice and how many watts should i run to them? Also it say the frequency response is 46-150 but on the specs for one thunder 6000 it is 31-150. What is up with that?
Okay, before I got my new subs I had I MTX 6000 in my Ranger.(I got a good deal on a thunderfrom box) This ONE sub supprised the heck out of me!!! It did everything that was needed to ride down the road and listen to quality music. I only had 200 watts running to it also. I believe that MTX is a good choice.
i just bought that same box with 3 subs in it off of uscaraudio.com it comes in on tuesday. sometime next week ima install it in my car running off of a MTX rt2600 i think the model number is sorry i havnt looked at it in a while.......the amp is 600watts bridged so each sub will be getting 200watts. il tell you how it sounds if you give me ur email........
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
851
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
Guest
Killa sin
