MTX Terminator Amp Issue
xxCarmaxx
MTX Terminator Amp problem?
I'm having a problem with my 600W MTX Terminator amp, when I turn my stereo on, it hits twice, then three red lights flash on top of the amp, at first I thought this was ground issue, so I used an actaul sander to sand down the ground spot to remove any and all paint, and refashioned the ground wire to the spot. That did not solve the issue.
Next, I turned my stereo on, and unplugged the remote wire from the amp while the stereo was on, then when I plugged the remote wire back in, the red lights stopped flashing and it worked. The issue is that I have to do this every time I want to listen to my subs. Are there any known solutions to this problem? I'd appreciate any and all constructive feedback, thank you!
- Austin
Do you have a DMM, check the voltage that comes through the remote wire to turn on, you want about 12 volts....also check the ohm load your subs are hooked up on it might be seeing too low of a load and going into protect mode
xxCarmaxx
xxCarmaxx
Missouri
All_Logix
ThxOne
    May 25, 2026
