Mtx te4001d
  • 6
soloXgt
Dinkum Flicka
MTX TE4001D
Works fine, but cosmetically, not 100%. The "black chrome" part can be shined up nicely, but the chrome part is a little pitted and won't get back to the chrome it was.
Features
Thunder Elite Series 1-Channel Class D Car Amplifier
RMS Power Rating @ 4 ohms: 1250 watts x 1 channel
RMS Power Rating @ 2 ohms: 2200 watts x 1 channel
RMS Power Rating @ 1 ohm: 3750 watts x 1 channel
Adaptive class D circuitry
MOS-FET power supply
Overload and thermal protection built-in
Speaker level inputs with Smart Engage signal sensing
Intelligent Surface Mount Technology (ISMT)
XTC (Xtant Technologies Cooling) : Internal cooling plenum, Active temperature monitoring and Variable speed fan
Prizm EFX control panel
Variable low-pass crossover (24 dB @ 40-200 Hz)
Subsonic filter (12dB @ 20-50 Hz)
1/0 or 4 ga. Power input
Parametric bass boost/cut (12 dB @ 30-80 Hz)
180 degree phase switch
Streetwires terminals and internal wiring
EBC port for included electronic bass control
CEA-2006 compliant
Dimensions: 20-11/16" L x 9-5/8" W x 2-1/2" H
$500
Shipping is on you
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
858
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
soloXgt
Dinkum Flicka
soloXgt
Buffalo/Rochester NY
soloXgt
