MTX 801D repair
ness1216
I have a MTX 801d, where the power connections go onto the amp is loose and can be moved up and down. I took the amp apart and say the points that go onto the circuit board is loose. My question is do I just need to solder these again to get it stable? I can solder but have never really messed with an amp before so I just wanted to make sure it would be ok. The amp plays fine as long as its making a connection which can be achieved by wiggling the power wires connected to the amp.
All it should need is a new solder, if you are doing it yourself just be carefull, especially if you have never messed with an amp. It isnt a hard fix if that is all that is wrong with it.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
ness1216
ness1216
Tampa, FL
revrider1
Mike Mccabe
