mtx 8000
Well, from what I've been able to dig up, the subs (not sure if they're tens or twelves - doesn't matter, same power handling on both) RMS at 250 watts @ 4 ohms. Peak is delivered at 500 watts at 4 ohms.
Next step would be to get me the specs and model of the amp.
Ok, set the HPF (high pass filter) at around 70Hz, keep the LPF off, don't filter anything.
Bridge the amp down to two channels, and hook a sub to each channel. If you have the DVC subs (dual voice coil) wire each one to achieve a 2ohm load to each channel of the bridged amp. That way you can get as much power as you can out of the amp.
Turn the gains to about 1/3, and go up from there. Listen carefully and if you start to hear distortion under higher volumes, turn them down a bit.
Thats really it, I hope that helps, let me know if there's anything that needs clearing up or anything that I left out.
laxplayer08
laxplayer08
Middle Township, Nj
laxplayer08
