Most power off Amplifer with 12V
To OP: tons of amps are available but with the electrical support you have, no matter what you have you will only be able to see so much power.
It takes power to make power.
Id suggest you clamp your Z1a, see what power your really getting out of it. See what your impedance rise is, and see what adjustments you can make to get more power. You have a great amp and honestly thats about all youd ever need for a nice loud daily system.
any testing to prove 24 runs does any better than just one or two? because i bet after like 4 it was pointless
My chevette has 36, it minimizes resistance. Allows for no strain when transferring power from front to back. Not saying it necessary, but if you are a hardcore competitor its worth the extra little gain.
To OP: tons of amps are available but with the electrical support you have, no matter what you have you will only be able to see so much power.It takes power to make power.
I have two run's but the thing is my batteries are in the trunk of my lincoln so like the electricity travels like 2 ft? does that have any consequence to making such massive runs?
bumpin i only asked because (forgot his name but runs cactus sounds in wi)
said he added a bunch of runs to his van and seen no difference from the original couple of runs he had.
if it works it works i was just wondering if there was proof of a gain. i mean if you keep adding runs and see a difference in each run you add thats awesome but if you add 20 more runs and after 4 or so it doesnt help thats just a giant waste of money.
anyways continue with the original post
Bhhong
Bhhong
SD DAYGO CALI
kurrupt
