Sold Morel Hybrid Oviation 6 - Retail for over $599 pr - $300 OBO
davidtemple
Caraudio Guru
Hybrid Ovation Midbass 6 - Morel 6" Midbass Drivers
REVIEW
I will post some pics later tonight these are mint! These are only the 6's no grills but you can order them from Morel ( NY ) for almost nothing....//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
* Nominal Impedance: 4 Ohm
* Power Handling : 160W
* Max. Transient Power Handling: 600W
* Sensitivity (2.83V/1M): 91dB
* Frequency Response: 35-3000Hz
* FS: 55Hz
* Voice Coil Diameter: 54mm (2.1")
* Voice Coil Height: 10.5mm (0.41")
* Voice Coil Type/Former: Aluminum
* Voice Coil Wire: Hexatech Aluminum
* DC Resistance: 3.2 Ohm
* Voice Coil Inductance @1kHz: 0.24MH
* Magnet System: Supremo Hybrid rear vented
* HE-Magnetic Gap Height: 5mm (0.2")
* B-Flux Density: 1T
* BL Product/BXL: 4.47
* Max. Linear Excursion/Xmax: 5.5mm (ᅡᄆ2.75mm)
* Suspension Compliance CMS: 870
* Mechanical Q Factor QES: 0.49
* Total Q Factor Q/T: 0.42
* QMS: 2.69
* Mechanical Resistance RMS: 0.60kgSᅡᄍ
* Moving Mass MMS: 9.3gr (0.33oz)
* Equivalent Car Air Load VAS: 17.3L (0.61ftᅡᄈ)
* Effective Pison Area SD: 119cmᅡᄇ (18.45inᅡᄇ)
* Cone Type: One-piece formed
* Cone Material: DPC
* Unit Diameter: 165mm (6ᅡᄑ")
* Mounting Depth: 61mm (2.37")
* Mounting Cutout: 141mm (5.55")
* Net Weight: 0.73kg (1.61lb)
davidtemple
Caraudio Guru
davidtemple
Louisville, KY
davidtemple
