Morel ACCUSET MX-33.3 x-over
Naxis2k1
grade A whiteboy
hey guys does anyone know if this x-over uses 4ohm drivers. or 6-to-8ohm drivers but shows the amp a 4ohm load. when reading the specs on it, it says the nominal impedence is 4ohms. but it beign morel i figured the drivers are 6-to-8ohms.
That crossover is designed for use with the Morel MT-23 tweeter, CDM-54 midrange and Elate 4/5/6 SW midbass driver. This means that it was designed for a 4-ohm midbass, 4-ohm midrange, and 6-ohm tweeter. Hope this helps you out!
Naxis2k1
grade A whiteboy
Naxis2k1
Phoenix
96GTIVR6
