I do not believe that the mesh will make it any more stronger than an extra 2 layers of heavier matting will. Its going to cause more problems later, just use more matte. Also, the rule of thumb on releasing your molds is at least 3 layers. If its too thin, then when applying the rest of the layers on top, the reaction of the resin and the catalyst (mekp) is exothermic, thus releasing heat. If the mold is too thin and gets too warm, it can actually warp and not fit back the way it was when. Which kinda defeats the main purpose of fglass in the first place ( to be able to accurately use odd, curved shapes for a custom fit). Are you doing kickpanels or what? Why not remove the seat for more working room? 3 or 4 layers of glass should only take about 4 hours or so to complete. You can begin laying another layer as soon as the resin is dry and non-tacky to the touch. And as someone already mentioned, you can do 2 layers of matting at a time. So in escence, by doing 3 repeated layers, you are actually laying down 6 layers of matting, so you should be fine with that mold.
