Monoblock Amp Help!
logan963
Alright, I have a JBL W12GTI-MKII, its rated at about 700rms and 4000 peak, what would be a good amp for it? I currently have a Hifonics Brutus 1200.1, but that just isn't pushing enough power to it at 4ohms. I have a budget of about $300 and would like to have something that will push about 800rms at 4ohms, all recommendations a welcome!
Sorry wouldn't let me post a link to it!
Don't think u can wire that sub to 4. They are dvc6, but I have this amp give it about 1k @3 also matching brand
JBL GTO1201.1II (gto12011ii) 1200 watts, Grand Touring Series
vfl 4480 is 2200 rms at 1 ohm 320 shipped new from me with warranty
Im liking the amp, but I can't find much info on it, what rms would it be putting out at 4 ohms, and what is the dampening factor on it?
it relatively a new amp offered by american bass ,there is a review done on the amp here .very efficient to .prolly only 600 rma at 4 ohms tho .run your one sub at 3 ohms for around 1000 rms on the 1 sub and when you get the other sub at 1.5 for 2000 rms
Sounds about perfect, is there any negotiating room on that price?
i have 4 gauge amp kits ,that i sell .this amp takes 4 gauge wire ,and like i said is very efficient . 4 gauge is fine for it .sorry for any confusion ,i'm talking to 3 people on amps ,and system right now .if you need an amp kit i can give you a really good price for one of my kits .i'll do all the crimping needed ,you'll just have to run the wire and install the amp wires to the amp .
Hifonics bxi2610d $240 shipped
Brutus BXI Single-Channel Monoblock Super-D Class Car Amplifier
RMS Power Rating:
4 ohms: 850 watts x 1 chan.
2 ohms: 1700 watts x 1 chan.
1 ohm: 2600 watts x 1 chan.
MOSFET Power supply
Super D-Class amplifier relies on a super-speed enhanced chip-set to produce higher current capacities and more precise digital to analog conversions
Link & Sync feature allows the mono amps to be strapped or bridges via master/slave configuration
Wired remote bass level control included
Power and Protection LED indicators
Built-in system diagnostics offer protection of DC, Speaker short, terminal, and overload
Tuned Bass EQ (0-10 dB bass boost at 45 Hz)
Dampening factor: >250
Single-channel monoblock channel operation
1-Ohm stable
Phase shift: 0-180 degrees
Preamp RCA outputs
Input level control: 0.04V - 18V
Balanced line input for MX accessories and line drivers
Heavy duty aluminum alloy heatsink for extreme heat dissipation
RCA level inputs
Screw terminals
Variable low-pass filter (35-250 Hz, 24 dB/octave)
Subsonic Filter (15-35 Hz at 24 dB)
Frequency response: 35-250 Hz
Dimensions: 17-3/4"L x 9-1/2"W x 2-1/2"H
0-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
I actually already have 4 gauge copper wire running through my vehicle from my current amp
Hifonics bxi2610d $240 shippedBrutus BXI Single-Channel Monoblock Super-D Class Car Amplifier
RMS Power Rating:
MOSFET Power supply
1-Ohm stable
Preamp RCA outputs
RCA level inputs
Screw terminals
sorry not very fond of hifonics lately
logan963
logan963
Dallas, TX
alec14
