So I have two D2 subs that I was going to wire together for a final load of 2ohms. If I use this amp below, and wire each sub at 1ohm to the inputs does the amp see a 1ohm final load or a 2ohm final load? I'm not sure how these newer amps are supposed to be wired that are monoblock but have the dual speaker terminals.
MB Quart ONX1.1500D - ONYX Class D Monoblock Car Amplifier/Amp
Everything I see doesn't really explain how these new terminals are working, I just know that they are meant to provide more wiring options. If I can wire these D2's to 1ohm each and run the amp at 1ohm final I would like to do that.
