Mono amp with 1 rca input,Y adapter?
Maxchaos
Hi!
I'm finishing up my build,on the front speaker I'm using one mono amp,that has only 1 rca input.
I don't really care for stereo or mono because it's a measure only system.
I was thinking about using an Y adapter to "merge" the L and R output in one RCA,so I don't loose any part of the audio track,because as I said the Stetsom ex8000eq only has one RCA input.
Will I damage something if I merge the 2 signals? Preout are 4 volts, will it go up to 8 volts?
Thanks you!
Will It damage something? Because I was reading that using a splitter to make 2 in 1 is like shorting the pre out,I think I Will try with a cheap h/u to see if It work well 😅
Maxchaos
Maxchaos
Italy
Maxchaos
