Mono Amp Help
Biggman44
Im looking for a new amp. I have 200 dollars to spend what is the cleanest strongest sub amp I can get for that price range. Im not a competitor or anything this will be for daily use to go along with my DD 2512 dual voice coil sub. So the amp im looking for would need to be 1 ohm stable thanx in advance...
You can also get the DSC1500.1D for $204. You can also get the AQ1200D for about $200 shipped used from the classifieds.
Yea i was looking at this dsc1500.1 im going to be powering a dd2215 or 2 RE SE 15'S do you think that amp will be strong enough i think the RE's are dual 4 ohm and the dd will be dual 2 ohm so i can run it at 1 ohm on the amp?? i think thats right
Yeah, the DSC1500.1D will give you the power you need. I don't know the exact specs of the DD sub, but I know it'll match up nicely with a pair of SE 15's if you wire the amp to 1-ohm. The amp pushes 1500w @ 1-ohm, so each sub will see 750w. The DSC amps are supposedly underrated, too...
Biggman44
Biggman44
Fairfield, CA
mclerico83
