mono amp...4 speaker terminals
aaron7114
Ive got a hifonics bx1605 d mono amp. However there is 2 positives and 2 negativs for the speaker hook ups on the amp. I've never seen a mono amp with 4 terminals.
I am wanting to run the amp at 1 ohm. Would I hook two positives into 1 terminal and two negatives into 1 terminal or would i hook up 1 positive to 1 positive terminal negative to negative terminal then same thing for the other 2 wires?
the positive and negs are connected together inside the amp. it just makes it easier to connect multiple sub to a mono amp.
So hooking up the speakers into the same terminals or into sperate terminals will give you the same result.
So, you broke each sub down to 2ohms and then ran each sub to the amp...
Yeah running 2 ohms out of each amp into the amp which gave it a 1 ohm load.
Also on the amp it has the low pass filter right...well when i have it turned all the way down (so its actually on) the bass isn't near as loud. But when I turn the filter all the way off (where the crossover is off) its a lot louder, just doesn't sound as good on some songs since of course some of the regular music and vocals are comin through the sub.
Why is this?
I have seen and had this question before. I have yet to see how it is easier or better to anyone. I will eventually own enough shares of Rf (ROFO) to influence them to influence the industry to stop this silliness.
aaron7114
aaron7114
Arkansas
Flipx99
