Sold Modified a/d/s A6iS crossovers
Lothar34
Donations Accepted
These were modified by robot underground for a component set that they sell or used to sell that they made with a 2Ω Orion woofer and a 4Ω tweeter. The components are all still very high quality a/d/s pieces except for the red cap on the woofer side, which is from Bennic.. The crossover points are 2600Hz LP for 2Ω @ 12dB/oct, and 2600Hz HP for 4Ω @ 18dB/oct.
If you don't have a 2Ω woofer, then this still may be useful if you want to use two 4Ω woofers wired in parallel with your passive setup. Or you can just take the components and use them for something else.
$35 plus $4.90 for priority mail or $9 for UPS ground. Paypal preferred.
They can also be used for a 3-way passive system. You can run your mid and your woofer off the LP output, and then throw in another LP filter for your woofer.
Lothar34
Donations Accepted
Lothar34
Pearland, TX
Lothar34
NorthFramingham
    Jun 30, 2026
