Moderate power question
Is it wise to think not to overwhelm the power between your front speakers and the subwoofers? If I have 300w going to the front should I double that to the subs without worrying about the bass sounding too dominate?
What would you suggest for a moderate power combination?
I thought I knew a little something but now I'm confused....I think I got brain freeze.
300w to the front is kind of a shit ton. I have 900w RMS on my subs and 125w RMS on my fronts, and it makes me want to orgasm.
It will be a Premier DEH p860mp, Focal 165V2 comps to a JL Audio 300/2.
I have about 400 to 500 dollars for the subs/amp combo and seems to be confused about what to use. The dealers around here mainly push JL's or Alpine's and would like your opinion for variety and balance. I do appreciate all replies.
Thanks
It just takes more wattage to push a sub than comps. Currently my Xtant is 50w X2 (@4ohms) and 250w x1 (at 2 ohms) and it balances fairly well, so the same ratio is about right. I would give your sub at least 500w if you have 150w going to comps, and set your gains (turn your comp gains down) to level match your sub.
g1underground
g1underground
WASHINGTON DC
bikejunkie223
vegang
vegang
