Modeling clay for glassing mold?
Well, if I glassed I could build out from the panel and use a larger format tweet. Plus I could angle the driver at any angle I needed instead of just crossfiring them.
I guess I could use the clay to hold the tweet in a specific location while testing for the optimum angle before I laid the glass down too.
just get some plastic bodyfiller (for PLASTICS) and call it a day.
Is that plastic bodyfiller moldable like modeling clay? I have neither used nor seen such a product before. I envisioned it like a thick glue.
Or would I use it over the clay instead of the fiberglass?
yes.
why not?
but also - why are you using fiberglass for a sailpod
I think req was saying that I should use filler instead of FG. I am guessing that he suggested that I use the filler over top of the clay to achieve the desired shape.
I did not explain that I will be using large format tweeters. They will be protruding an inch or more from the panel with a hefty weight. I do not think that filler alone will support the tweet.
Finleyville
Finleyville
Pittsburgh, PA
Atomic
