Specs on the Pro-Cast Series
This series is the flagship of our poly-cone subwoofers. With more magnet, more voice coil, more excursion, more power handling and cast aluminum basket, the ProCast Series is our most efficient (96 1w1m) & powerful subwoofer. It can be used for SQ or SPL
• 50-mil polypropylene Starburst cone. Greater musical reproduction accuracy than our “MMATS” & “Pro” Series Subwoofers.
• High excursion 1.1” wide x .70” tall polyester foam surround, extremely flexible and very linear.
• Heavy-duty cast-aluminum frame – No Flex as compared to Stamped Steel.
• 3.0” Aluminum voice coil with a 1.25” winding length. Nomex reinforced collar for superior heat dissipation. Dual 4 + 4 ohms.
• 140 ounce double-stacked magnets with “MMATS” embossed rubber cover.
• Hyper-extended pole-piece. This lowers distortion and creates a more linear magnetic field.
• “Nomex” 8” flat spider w/reinforced collar provides symmetrical control of the voice coil through its excursion (no rocking).
• 1” vented pole piece for maximum thermal efficiency.
• Standard front gasket.
