MMATS Juggernaut 15 Motor/Basket --- Affordable---
  • 4
BassAddictJ
FL
Mmats Juggernaut 15 Motor and basket
I'm pretty sure the motor is shared with an older DD 9500 series, B or C maybe. If someone knows for sure please chime in and let us know.
I picked up this blown juggy 15 today. It WAS a dual 2ohm but there's a fried coil and a bad tensile on the other side.
Motor is in overall good condition. Slugs are aligned, no cracks, no major chips beyond typical wear miniscule chip off a corner....barely noticable and wont effect anything. There's some glue leftover where the basket screws down but a razor will take that off easily.
The basket....I accidentally stripped the head of one of the screws for the basket (used the wrong drill bit like a dumb ****). So i was going to break the bolt by twisting the basket and sure enough the that one spot on the basket broke instead of the bolt. That being said the bolt came out of the motor fine, no damage to the motor whatso ever, and the basket has that one (of six) bolt spots gone. The good news is you can still use the basket on this motor (or others) without issue as the mmats motor only uses 3 holes on the motor, and with the 6 holes on the basket it can be lined up to utilize all 3 mounting holes. even though that bolting spot is broken off the brest of the surrounding basket bolt mount area seems uneffected and plenty sturdy. It was just alot of pressure at that one angle that broke that small section off.
The original cone and dustcap are still in good chape and I can throw if for free if requested to the first buyer. Also to the buyer of the motor i can include the original blown VC so you have a something to go off of to get another fitting coil. It's a 3in or just barely over 3in coil.
Motor alone - $100+ ship (usps large flat rate shippd and insured to your door for $117.50)
Basket alone - $10+ ship
Motor + Basket - $150 shipped (being so large and heavy this price hike goes stright into covering shipping expenses).
NO TRADES and prices are pretty sure as they are already cheap for quality gear.
Fedex Ground or USPS Parcel Post
here you can see the basket lined up to fit perfectly with the motor's 3 mounting holes even though there's a chunk missing.
cone and dustcap before cutting the surround/spider:
Ref's: Years of selling here. You're in good hands.
PM me with any questions
is it really a jugg? or just a jugg recone? never seen a motor like it from mmats, just curious its alot different from mine.
it doesnt have the typical jugg logo aoround the motor boot, i figured it had just came off at some point. the coil looks identical to another jugg vc posted on my thread on caco. and it looks just like an older dd9500 motor, which i though dd made for mmats anyway...
wether its a true jugg or just a 9500 motor its still hella cheap. someone buy this!
ttt for a cheap motor.
i can include the old voice coil so you have somethign to measure and/or send to someone who makes recones so they can find you a fitting coil.
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
BassAddictJ
BassAddictJ
FL
BassAddictJ
Decebal
    Jun 10, 2024
